I agree with the Rusty Man. If it takes the modern (to me at least lol) 18mm plugs the Auotolite 386 is near the original factory heat range I believe, while the 388 is a tad hotter AND I WOULDNT MESS WITH ANY ADAPTERS. If its a Magneto Id consider the Autolite 3116 NON Resistor plug instead. Things that can help reduce plug fouling (esp in a parade light use tractor) are to keep the temp up to 180 and more,,,,,,,dont run the carb any richer then necessary,,,,,,,,,use a hotter plug,,,,,,,keep ignition well tuned with good points n condensor and wire core plug wires......
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
