Re: Farmall C Voltage Regulator
Posted by riverbend on August 17, 2013 at 18:49:03 from (70.101.157.162):
In Reply to: Farmall C Voltage Regulator posted by burnsg2003 on August 16, 2013 at 16:59:13:
6V voltage regulators are mostly junk.
When I replaced the VR on my SC it would not charge. Bad words were said. Then I noticed that I had not reconnected the field wire to the generator.
You might have a bad VR, but it won't hurt to check the wiring.
Greg
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
