Posted by hayfarmer on August 22, 2013 at 12:26:38 from (68.118.216.133):
Having a couple problems. One is back and forth movement of distributor shaft, probably 1/8 inch or close. From looking at parts book I suspect I need to replace thrust washers. 2nd problem is getting oil in distributor. I know it is from the hydraulic pump. could swear there used to be a drip hole in the bottom of the housing between the distributor and think mine used to drip there but can't find it now. Am I wrong about drip hole or where is it located on housing? thanks in advance for help, need to fix problem with pump seals but trying to get some hay put up first
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
