Posted by Janicholson on August 29, 2013 at 19:18:08 from (74.60.94.18):
In Reply to: still wont crank posted by twiggcas on August 29, 2013 at 18:15:37:
It is intake. The stem will get stuck in the guide from gum, rust or corrosion. When turned the force of the cam and the valve not moving will bend the pushrod. Get a new one if the valves move now it will be OK in that regard. Most Hs and Ms do not have valve interference and are not crash engines. Bad timing can cause the issue you describe.. assure it is at TDC when not moving and be sure the cables are as fat as your little finger with copper, (not the insulation) they should be 00gauge copper with soldered on terminals. Keep us informed. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
