Posted by JimB2 on August 31, 2013 at 17:14:40 from (99.241.76.141):
In Reply to: IH Model 434 posted by Greg DuCote on August 31, 2013 at 15:58:30:
Hi, see http://users.telenet.be/IH-SBWD6/IHnummersGB.htm for serial numbers.
I assume it is a BD-154 Diesel?
There were a couple different part numbers for water pump depending on application of BD-154 and I believe if the water pump had a thermostat bypass or not. See caseih.com parts at: http://partstore.caseih.com/us/parts-search.html#epc::mr50025ar426816
Try googling 703820R97 sometimes they appear on ebay. DO NOT try changing the drive shaft and bearing without a press or the casting will break.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
