mower for farmall A
Posted by Matthew Trefz on December 01, 2000 at 12:53:58 from (140.254.102.79):
I recently purchased a sickle bar mower for a farmall A. The mower is mounted under the tractor's belly. My question involves the piece which mounts on the pto shaft. It is a piece that has the correct fitting on one end to go over the pto. On the other end of the piece is a pulley. This pulley is supposed to have a belt on it that runs to another pulley which drives a shaft which runs the pitlan rod on the mower. I need the piece with the pulley on one end and the pto hookup on the other. If anyone knows where i can find it I would be happy to receive the info. Thanks
Post A Followup
: Re: mower for farmall A
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
