Posted by Janicholson on September 15, 2013 at 07:27:13 from (74.60.94.18):
In Reply to: starting problem 3414 posted by keith smith on September 14, 2013 at 12:55:28:
our starter and ignition are tied together so that when starting the coil gets full battary voltage using a bypass wire to the coil side of the ballast resistor if this wire gets loosened from pressure washing it will cause the issue. many ignition systems need the added voltage of the bypass. Also check the battery condition A weakening battery will still crank, but its voltage will be too low to fire the plugs untill the key is relaesed. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
