Posted by c4thisguy on September 15, 2013 at 15:48:48 from (76.177.68.39):
I have a 574 international tractor with 200gas engine. It will run but blows alot of black smoke like it is flooding. It will run awhile and die... I've put new plugs points condenser added new fuel pump had head checked valves ground, added all new gaskets. I've put everything on it but a new distributor. Noticed were the wires bolt on to the distributor, the little plastic piece was cracked, so I put a piece of tape over it, but it didnt help a bit. Got new coil and tried another coil, but same thing. put new carburetor as well on it. Pulled number 1 and number 4 wire off but motor runs the same.
I'm really at a loss as to what is wrong with this tractor, so I'd appreciate any help anyone can give. thanks
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
