Posted by deereabhm on September 18, 2013 at 08:16:53 from (24.27.184.206):
Looking at this Case IH 885 with really low hours. It hasn't been run much at all which is probably what is causing this problem.
The diff lock pedal will not press down. Also the diff lock light is stuck on. I can make turns and use the brakes to stop the left or right wheel so it doesn't look like the diff lock is actually engaged as it says it is. What is wrong with it?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
