Posted by Owen Aaland on September 25, 2013 at 13:50:42 from (216.47.35.219):
In Reply to: h starter drive posted by lmika on September 25, 2013 at 12:45:31:
The drive you received is the original style.
To remove the newer style drive you need to move the washer that covers the set screw toward the gear. I usually use a couple of screw drivers to pry it forward and then hold it with one of them as I loosen the screw. Once the screw is far enough out it will keep the washer from returning all the way back. If you are going to reinstall the same drive do not take the screw all the way out,
You can use the older style drive but you will be missing two stop washers that keep the drive from going to far forward. The newer style drive does not use them.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
