Posted by Tom Fleming on October 02, 2013 at 04:28:07 from (67.20.233.75):
In Reply to: F20 coolant leak posted by doehmke on October 01, 2013 at 19:31:42:
Not a problem. The F-series does not seal everything up tight like 36F30 says. They will seep a little around seals and that is a fact of life. However, the head bolts, manifold bolts, oil pan bolts, some of the transmission bolt are open to the fluid chambers (oil pan, cooling jacket, transmission, etc.) these bolts/studs all should get a dab of your sealant of choice. I like permatex, however, use what YOU like and have good experience with. None of these are high pressure, so like the old TV commercial, " a little dab will do ya".
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
