Posted by SDE on October 12, 2013 at 11:04:34 from (174.124.134.196):
I jacked the tire up and have drained as much fluid out as I could. Can I remove the tire, with the wheel and cast center still on the tractor? How do you remove the ring? Does it require a special tool to wedge into a gap and then pry it up? I took a hammer and a bar and tried to unseat the ring but if it can be done that way, I will need a bigger hammer and another hand. I have read some warnings but no one covered how to remove the ring, other than to put the pry bar in the gap. Thank you SDE
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
