Posted by Lmack on October 23, 2013 at 11:45:39 from (24.131.50.165):
In Reply to: trans fluid level posted by ronztractor on October 22, 2013 at 19:15:31:
If for some reason it has been setting out in the rain, remove the bottom drain first to check for water in the transmission. If you have water let it drain (cold after setting for a while) until the water stops. Then check the fluid level as Jim has indicated. Do not over fill.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
