Posted by RandyM on October 27, 2013 at 14:14:39 from (74.67.145.43):
Hello all, working on my 230 clutch. (Tractor s/n 1336J – so a Rockford clutch) It has for some time been grinding when shifting into any gear. It does not settle out even if waiting a minute or so to change gears after depressing the clutch. The clutch rod adjustment is nearly bottomed out. The throw out bearing was getting about ¾” movement when the pedal was operated at that adjustment however the release levers were moving very little. There was a good quantity of metal dust when I pulled it apart which I now believe to be the pilot bushing. It appears to be nearly gone although everything else seems to be in good shape. I have the tractor split and the clutch disc and pressure plate out. I am getting ready to order necessary parts.
My first question is about the normal thickness of the clutch disc and pressure plate. I have a rough check of the clutch plate at 0.32 inches. I believe these were new several years back, but the tractor has had very little use. They look to have a lot of wear left in them. If they are serviceable, then I’ll need only some smaller parts to do the repairs.
Preparing for the worst, I web searched for individual parts or complete kits. I am using parts book TC-53B. That book (p 160) shows the pressure plate assembly as part no. 353 242 R92. I have not found anyone online that has that part number for the Farmall 230. I don’t want to spend a few hundred dollars for something that isn’t going to work.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
