The caseIH parts diagram shows only one on the right between the trans casting, and the left brake pedal attaching point. If you need another it is not a problem using a steel washer with the correct inside diameter. Valve spring shims from a autoparts store are really good substitutes, Take the shaft diameter with you to seelect the correct shim. If they want to sell you 8 of them, find a rebuilder that will give you a ferr used one. Jim
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
