Calling the smart guys....Please Verify?
Posted by Allan In NE on November 26, 2013 at 16:15:36 from (199.47.66.61):
Tell me if I'm on the right track.
5488 power steerin problem. Been running checks on everything under the sun for 3 weeks now and can't put my finger on the culprit.
In despiration, I throw everything back together, then the dog and I go for a long drive with 'er down in the pasture.
I notice that if I keep the revs up over say 1550 or so, steering is just fine; idle it down and I've immediately got the armstrong thing going on.
To my mind that eleminates the hand pump and the cylinder 'cause it really gets hard to turn and there is no slippage.
Regulated pressure is on the low side at 240 lbs and this gal did not have a bypass valve in the steering/lube filter (that wipes out pumps).
I think I bought it just when the gear pump is "beginning to fail"? To me, reving it up and getting the steering back just screams weak pump??
Whatcha think?
Allan
third party image
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
