Timing the iginition on a Farmall H - two marks on pulley
Posted by andy r on December 13, 2013 at 23:56:30 from (75.91.149.15):
Setting the distributor on a Farmall H. When I brought the number one cylinder up to top dead center on the compression stroke the steel pointer lines up with the marks (notches) on the crankshaft pulley. That is just the problem - there are two notches on the pulley. They must be about 1/2 inch apart or so (can't remember exactly). Which one do I use to set the timing with the engine not running??? Why are there two - what is the purpose of the other notch? Thanks.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
