Posted by The tractor vet on January 01, 2014 at 14:51:18 from (75.19.125.103):
In Reply to: 986 pto problem posted by zimerj on January 01, 2014 at 12:26:03:
First off a pressure check is where to start , ya may get by with just and adjustment then again it might be as bad as the center housing where the teflon seals ride maybe scrap. Could be a bad seal on the the pick up tube or a loose floppen around tube. . You can check the pick up tune by pulling the top link bracket off and looking in and see if the pick up tube is loose as they do not take kindly to abuse as i have fixed many .
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
