Posted by buggsy on January 22, 2014 at 10:14:02 from (198.254.229.69):
In Reply to: Farmall A axle seal posted by Farmall A Tractor on January 22, 2014 at 04:28:54:
i just finished doing that to mine, there is a felt washer as well as a seal there, i unbolted at the axle , took cover off other side and bottom pan because you need to be able to put gear washer and sleeve back on shaft then drive out with a socket that will fit inside of bearing
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
