Your problem sounds like the TA clutch has failed, as Janicholson descirbes. Either that, or your TA adjustment is WAY out of whack.
The TA clutch usually goes because the adjustment was wrong. If you set the short linkage between the main clutch arm and the TA arm too tight, the TA clutch slips and burns up. Same thing happens if you adjust the TA lever linkage too tight.
There is an inspection cover on top of the torque tube (under the gas tank) that you can remove to look at the TA clutch.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
