Posted by redforlife on January 29, 2014 at 14:45:24 from (68.234.121.124):
In Reply to: Engine Unlocking Tips posted by FarmallGuy1923 on January 28, 2014 at 18:56:44:
many lubricants are used. Bottom line is-its good for pistons to be soaking with something. one trick I heard about but never tried is if head is still on, take rocker arms off closing the valves, take spark plug out preferably out of the hole that is stuck if ya know which one it is and in an up position (can't do it on a bottom dead center piston), get a hydralic fitting that will screw into the plug hole, then simply hook it up to the hydraulics of another tractor, and use hydralic pressure to force it loose. (Important)when engine moves, take away the hydraulic pressure cause piston will end up at bottom dead center and there will be nowhere for the pressure to go. then something might break or blow up.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
