The size being refers to is the outer diameter of the flange.
The crankshaft needs to be in the correct location to get the bearing to roll into place. You only have a few thousands of an inch clearance there. You will need to move the shaft forward or back to get it in the correct place.
The C-221 engines in the 460 used the 3 3/4" flange bearing but I have always been able to used the wider flange one when overhauling them. You may want to check for sure that your block has been machined enough to accept the wider flange. I think all the blocks were machined to be able to use the wider bearing but it doesn't hurt to check. The 560 used the same block and they came with the wider bearing.
This post was edited by Owen Aaland at 15:16:36 02/02/14.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
