Posted by freddy on February 16, 2014 at 08:22:12 from (108.73.25.112):
Well after much delay we finally tore down the 282D engine. Number 5 exhaust valve broke off about a 1/4" above its head jumped over and with help pounded a new hole in the head. Piston's mangled, pretty sure rod is bent, Unknown crank condition. water poured in to other cylinders thru exhaust manifold I am pretty sure. all cylinder had new pistons and sleeves -over size. Injectors were reworked. total rebuild of injector pump. Now we need to see what we can do with this mess. thanks for all the info on the 301 gas build up because it looks to be where we are going.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
