Posted by andyd4ntx on March 14, 2014 at 18:53:15 from (67.221.137.35):
Hi all:
I am having steering problems with my 1974 IH2500B / 574 loader tractor with the steering not working and after some troubleshooting and searching of the archives, I decided that I would pull the "Flow Divider valve" (priority valve) out of the MCV.
My problem is that after I remove plug and the spring the valve is stuck up inside the MCV, it won't come out!:evil:
Here is what I have already tried....
I ran the tractor with the plug and spring out and a bucket under the MCV hoping it would push the valve out, No Go!
A pair of needle nose pliers didn't work.
I have also tried a 4MM bolt and nut with a 5/16 fuel hose over the bolt, I tightening it in the base of the valve where the spring goes into, and tried to pull it out with a pair of vicegrips. NoJoy!
The Flow divider valve is so tight that it will not pull down and out of the MCV.
My next step is to use a lead redhead anchor in the base of the valve where I tried the 4MM bolt and fuel hose.
Are there any other tricks to try?
I am surprised this thing is not threaded inside so you could get a bolt into it to pull it out.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
