1086 gears grinding
Posted by Russell Moore on March 16, 2014 at 12:46:52 from (74.243.158.186):
I have tried to adjust the linkage on my shifters and I also adjusted my clutch it got better but it still grinds
if you put it in neutral and let the clutch out then try to shift it into high low or reverse it grinds
once you have it in range if you try to shift from gear to gear it grinds and sometime will not even go into gear
any help or suggestions would be great thanks
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
