Yes, pressure plates can absolutely be re-surfaced. But like a brake rotor, there are minimum thickness dimensions that need to be followed. Heat distribution is a consideration, and when they get too thin, heat doesn't dissipate and they will warp. Also, there needs to be appropriate clearance for the mounting bolts, as the heads are recessed. Any reputable clutch or engine shop will be able to do it and also make sure that it is within specs.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
