Posted by BrianK on April 20, 2014 at 09:55:12 from (72.171.192.62):
I posted this several days ago and I did not get any responses, so I will try again.
I am trying to drain my hydraulic fluid and according to my manual I have 2 drain plugs. One for the tank (which I found) and one for the transmission. The manual gives me a generic location (in front of the transmission) but there are 15 bolts on the bottom of transmission plate. The manual has these bolts attached to eternal pumps. There are 3 oversized bolts but according to the manual these are connected to relief and pressure type valves.
I am puzzled as to where the drain is.
My tractor has a backhoe attached if this helps.
Can anyone tell me where the forward drain plug is?
If I can"t find the drain plug can I remove the hyraulic hose that enters the bottom of the tranmission to empty the fluid?
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
