Posted by mattwillson on April 26, 2014 at 18:22:43 from (24.114.60.167):
Today worked out well. Turned on the gas, engaged the battery disconnect switch and climbed aboard. The ole mare flashed right away, a little choke and a little black smoke...gave her a minute, backed her out of the barn. a quick spin up the driveway and back, then into the shop. I installed the murphy's roller rockers that I bought last fall, then filed and gapped the plugs, lubed the wastegate on the turbo and changed the oil...next on the list is to take it to a dyno and see what it has... If anyone is looking for a good belly pump or a belt pulley drive assembly, they're pretty much free to a good home.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
