Also consider the wear of the shaft inside the bushing and the housing outside the bushing, so an OEM bushing won't take up the slop, and it's not likely anyone makes prefabricated bushings with such specific measurements.
Your idea of getting ones that are close should work. If they don't give a satisfactory fit out of the box, hopefully they're slightly tight, so you can massage them with grinding/filing/sanding.
The other option is taking the measurements to a machine shop and having custom bushings turned.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
