Re: Loader fit
Posted by mkirsch on May 08, 2014 at 05:05:28 from (65.199.189.6):
In Reply to: Loader fit posted by Notjustair on May 07, 2014 at 19:26:14:
The distance between frame rails is the same on an M as the 460 and 560. Axle housings are very similar in size and shape.
Going by the pictures online, it looks like the GB 800 loader mounts like an IH 2000. If that is the case, the front mounts have a lot of leeway front-to-back, so the difference in length won't be a problem. The loader frame will just extend past the M's front end by an extra few inches.
Other than getting bolt holes to line up on the front mounts, you should have an easy time mounting it on an M.
Hopefully, your M has power steering or you're built like a 1980's professional wrestler.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
