Posted by nosih on May 20, 2014 at 16:19:40 from (68.115.22.175):
In Reply to: MD update posted by BruceS. on May 20, 2014 at 15:19:24:
probably correct about the wrong head gasket. If the sleeves stick above the block, the standard head gasket will work. if the sleeves sit flush with the block, the 305805R1 special head gasket as it makes up the fire ring of the piston, and is engineered to crush correctly and seal the block and head. If the standard head gasket is used with the flush sleeves, the sleeve will move, and break the flange off of the sleeve and suck the sleeve into the block.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
