Re: 656 issues
Posted by pete 23 on June 20, 2014 at 09:12:44 from (74.33.68.123):
In Reply to: 656 issues posted by greg k on June 20, 2014 at 05:32:06:
No gasket under that cap. Just o-ring. Putting a gasket would lessen the sealing of the o-ring. I has a leaker couple years ago, not pouring it out but leaking, that someone had not installed the o-ring that goes on the sleeve piston rides in. Was able to pull sleeve out a little and put an o-ring on it. Those lines leak more often than anything else.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
