Re: Another Lift-All Question
Posted by mkirsch on July 02, 2014 at 11:36:37 from (65.199.189.6):
In Reply to: Another Lift-All Question posted by jsr8011 on July 02, 2014 at 09:08:32:
Any single port on the belly pump will flow all the belly pump can flow.
So, simply connect one output from the belly pump to the in port on the OC valve.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo ... [Read Article]
Latest Ad: Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use. [More Ads]
