Posted by Farmallfever1947 on July 24, 2014 at 19:59:24 from (70.194.195.145):
In Reply to: How To Set MD Timing posted by John Clarkin on July 24, 2014 at 17:56:53:
First get the number one cylinder at top dead center. Then set your mag so that you know which wire is number one. Then hook all other wires up accordingly and start the engine on gas. These engines don"t have alot of rpm adjust on the gas side except for what you can do with the choke but then try to get a timing light on it. You may need to use a separate 12v battery to power it but just see how your light lines up with the timing marks then adjust as needed. Also I know way back when they used to set the no1 cylinder to the timing mark and with the mag at full retard you can rotate it towards advance very slowly until you heard the impulse coupler snap. That"s works well too its just not as accurate. Used that method on my Deere and it runs like it should. Just always be sure that when dealing with the ignition on one of these diesels that it turns counter clockwise unlike the gassers. Good luck and let us know how it turns out. Oh and post a pic too. God bless.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
