Posted by gbs on August 11, 2014 at 17:18:27 from (70.197.181.219):
In Reply to: gear whine posted by Ellis Kinney on August 11, 2014 at 09:12:57:
it want hurt that modern 90wt that pours like 30 wt motor is most of the problem, daddy always run 140 wt in an m and its still going today, you can't find true 140wt anymore it's close but not the same 90-140 isn't much different than 90wt should be, we also use 140wt in an h with no problems, I got a super a that after replacing bearings and seals in the transmission and rear end it was filled with 90-140 and the gears seem to clash worse even waiting a little longer for the transmission to stop spinning before trying to shift into a gear 4 bottles of stp stopped that 20 years ago,also we don't live where temperatures get as low as they do up north
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
