Posted by Owen Aaland on August 20, 2014 at 08:44:02 from (216.47.34.49):
In Reply to: ih 444 rear end posted by international606 on August 19, 2014 at 09:47:08:
international606 said: (quoted from post at 12:47:08 08/19/14) i was wanting to know what rear end oil capacity is for a ih 444 rear end. Also how do you check it. If I remember right it is hy tran and you fill it 1" below the fill hole on the right side of the gear shifter.
Standard oil capacity is 5 gallons. The plug to check the level is just under the step platform on the fight side, just ahead of the park brake lever. The front crankshaft mounted pump was an option for the 2444. If used the capacity was increased to 14 gallons and the level is checked by measuring down six inches from the fill plug.
This post was edited by Owen Aaland at 11:45:17 08/21/14.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
