Re: Load of Red
Posted by WellWorn on August 24, 2014 at 06:52:29 from (75.251.0.89):
In Reply to: Load of Red posted by caseman-d on August 23, 2014 at 20:51:30:
Many tractors have loaded rears. That last tractor is making for a lot of 'leverage' on the tail end. Ideally the load should be mostly on the trailer axle, with about 30% (or so) on the hitch. Trailering things too well balanced or even worse, tail heavy, can 'whip-saw' the towing vehicle right off the road. I had it happen to me once because I was in a hurry and thought "it ain't loaded that bad". Never, Ever Again.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
