Posted by jimb2 on August 31, 2014 at 06:02:03 from (99.241.118.87):
In Reply to: IH 584 clutch posted by Glenn from calgary on August 30, 2014 at 19:33:15:
Hi Glenn, the 584 depending when it was made could have a self adjusting clutch where the clutch release bearing always rides on the pressure plate fingers. My brother's 495 had this clutch and the release bearing started squealing about 3 years after he bought it. When we did a clutch job we returned it to the old style with the return spring to pull the clutch pedal up so the release bearing stops turning.
See regular clutch at: http://partstore.caseih.com/us/parts- search.html#epc::mr52557ar374263
Major difference is item #10 return spring on self adjusting clutch holds clutch pedal down so release bearing is always turning and on standard clutch item #10 clutch return spring holds clutch pedal up so release bearing does not contact pressure plate fingers and does not turn when clutch is engaged.
Also item #3 can stick on item #5 with accumulation of clutch dust and dirt. There is no lubrication points within clutch housing but inspection plate at bottom can be removed and the workings can be observed.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
