Posted by pete 23 on September 05, 2014 at 10:02:23 from (173.87.12.198):
In Reply to: regulator question posted by charlie M on September 04, 2014 at 18:01:27:
Well, now you can use fine sand paper, emery cloth or a file. Can't get more confusing than that can it. A riffle file is what you are supposed to use according to the good book but not too many even know what that is let alone have one. Any fine paper or cloth will work. You just have to get it clean again after you polish them as that is what causes them to burn , not the grit embeded in the points. The spring adjusts the voltage setting so if it works ok after you rap it I would guess it is close to correct but only a volt meter will tell you for sure.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
