Posted by Owen Aaland on September 08, 2014 at 16:39:39 from (216.47.34.49):
In Reply to: Hot Coil and voltage posted by clint s on September 08, 2014 at 13:25:54:
The voltage at the distributor with the ignition on and engine not running should be either battery voltage or no voltage. This is true whether or not you has a ballast resistor in series with the ignition feed on the coil. With the engine running the voltage will be constantly changing between those two values. The voltage you are seeing indicates that the points are closed about half the time and open about an equal amount of time. Your meter is not able to react to the changes in voltage fast enough so what you are seeing is an average of the two values.
To determine whether or not you should have a ballast resistor you need to measure the resistance of the coil. If the resistance is about 1.5 - 2 ohms use a ballast resistor of the about same value. If the resistance is 3.5 - 4 ohms do not use a ballast resistor.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
