Posted by WellWorn on September 21, 2014 at 11:32:47 from (75.193.57.173):
In Reply to: Super C additional HP posted by BoonvilleKid on September 21, 2014 at 11:15:58:
Hi BoonvilleKid,
The early C had a 113cid motor, which was later changed to a 123cid. I believe both engines had the option of dome pistons for high altitude use. Most people rebuilding them opt for the 123 sleeves and dome pistons for a little more spunk. Rods, bearings and all are the same. Sleeves depend on the age of the block - the top flange and diameter of the sleeve changed during the production run. Best bet is to pull a sleeve and measure what you have, then match it except for the bore (3 1/8 for the 123, vs 3" for the 113).
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
