Re: timing a farmall C magneto
Posted by pete 23 on September 22, 2014 at 10:29:33 from (74.33.79.62):
In Reply to: timing a farmall C magneto posted by Chesterton angelo on September 22, 2014 at 09:26:48:
With the timing mark on flywheel aligned with indentation of flywheel cover, pull your magneto as far as it will come out, lock it down, turn engine until it trips and see how far it has to turn. Up to five degrees after top dead center is perfect. If more, well, something is amiss. I know there is no 5 degree on that model but a little head scratching can figure that out. About 1/2 inch,
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
