Posted by pete 23 on September 22, 2014 at 10:35:59 from (74.33.79.62):
In Reply to: bad injectors? posted by reggie1086 on September 22, 2014 at 08:39:10:
If you can catch it while it is misfiring and certain it is on a particular cyl, not sputtering around on different cylinder, you can feel the lines. If one is warm, you found your leaker. With engine shut off, pull injection line off that nozzle, crank engine with starter, fuel shut off and if compression comes out nozzle, you have a leaker. Low fuel pressure due to pump problems, fuel filter problems etc will cause scattered misfires and auto advance to not advance causing same thing.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
