Re: 464 Remote Lever Stuck
Posted by Charliet05 on October 07, 2014 at 16:54:21 from (209.105.132.240):
In Reply to: 464 Remote Lever Stuck posted by Charliet05 on October 06, 2014 at 18:30:45:
Found my problem!
Removed the remote valve assembly. Found a piece of "curled wire like" metal in the spool area (larger valve block center hole). Removed metal. Took a while!!! Re-installed valve assembly. Started engine. Let run long enough to purge the air from hydraulic system. Valve lever now moves smoothly from neutral to upper position and back to neutral. Same for the lower position.
Took the valve body to local Case IH dealership. Mechanic (IH experienced) "looked at" the metal. Couldn't determine what the metal was or exactly "where it came from".
I think the "larger center hole" is the fluid input. Still do not know what the metal might be. Or how it "got to" the valve spool.
Any suggestions will be greatly appreciated.
Very good site and forum. Excellent resource. Use it a lot. Have two older IH diesel tractors.
Charlie
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
