Posted by 151 on October 10, 2014 at 07:32:21 from (104.36.234.114):
hi just rebuit206D motor starts hard when cold white smoke starts very good after first cold start timing set at 14 degrees the early manual spec. the owners manual says 8 degrees motor only has 2 hrs. on it I thing I should move timing to 8 degrees it could be to that rings not seated yet it has the Bosch VE pump has to be timed with dial indicator any in put would be Appreciate thank you
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
