Still not on yet. Had to drill out rusted frozen axle bolts. I broke them off first and drilled out the rest. I then removed the tie rods so that the axle tubes could be slid out (was the plan). They would not slide at all though. Used 2 chains and a tree, pulling away. The axles are frozen and still would not budge. Tried to install it with the axles in place, but it is too heavy and awkward. It rolled off the floor jack. Had a hard time getting the old narrow front end off. It was frozen. Drove it around with loosened bolts and it broke free finally. Ended up putting the narrow front back on for now. I'll have to figure out a better way to lift the wide front into place. May use the 3 point on a different tractor if I can get it stabilized to where it will match up underneath. Very frustrating.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
