Posted by philip doolittle on December 01, 2014 at 06:43:16 from (50.102.253.187):
In Reply to: AM radio posted by bmagee on December 01, 2014 at 05:27:33:
Static noise on your radio can be reduced by putting a .1 microfarad capacitor on the + (positive) terminal to tractor ground. Capacitor should be rarted for at least 50 volts or higher and plastic for weather reasons. That said "Radio Shack" make noise reducers that also contain a small inducter ( chock coil) which sells as a" NOISE "eliminator. Either is not very expensive, If you still have too much noise you may find that a shielded wire for the 12 volt( maybe 6 volt) power lead with the shield ONLY connected to ground at the radio end. Hope this helps.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
