Clean the cylinders as best you can, maybe get in there with a small wire wheel. Then soak a few days with ATD+acetone mixture. If it's still locked up, it's time to pull the engine and completely disassemble it. Most likely need to replace the sleeves, pistons, bearings, etc. If you do get it to turn over you may still want to take it apart because the rings may be stuck to the pistons and won't seal right even if there's no wear on the sleeves. You really have to take it apart to see what you have. Not cheap, but if you do it right you'll never do it again with todays modern oils.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
