Re: A couple Farmall Questions
Posted by pete 23 on December 09, 2014 at 19:36:13 from (74.33.73.215):
In Reply to: A couple Farmall Questions posted by F150Mustang on December 09, 2014 at 19:09:25:
The working innards of the two pumps are the same. The difference lies in the housing layouts. Early pumps on both H & M were lower pressure(which is changed by different relief valve) and the gear bodies did not have shim packs for adjusting the end play of the gears.
  Upload Photo  Select Gallery Photo  Attach Serial No List
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
