Your 340 has an open center system. You will want an open center hydraulic valve.
Open center means that the fluid circulates under low pressure when all the spool valves are in the center position. This is how early hydraulic systems worked. If flow is blocked and can't go anywhere such as through a motor or into a cylinder, the relief valve pops off and relieves the pressure. If the relief valve fails, hoses blow, pump housings split, etc..
Closed center means the hydraulic fluid stays at high pressure and does not circulate. It is a much more complicated system requiring a variable-displacement pump and an accumulator, but it provides instant response to the hydraulics. Most tractors made from the 1980's on have closed center systems.
Today's Featured Article - Diagnosing Engine Difficulty - Diesel Tractors - by Staff. The following suggestions are listed for your assistance. You can make simple adjustments on your tractor that will improve its operation and save you the time and expense of hiring someone to do it for you. Always make one adjustment at a time, and if the adjustment made does not improve the condition, return to the original setting before proceeding to the next adjustment. Hard Starting Cold air temperatures. Insufficient fuel.
... [Read Article]
Latest Ad:
[More Ads]
